TeleFragger
- Nov 10, 2005
Ok so my hp professional workstation xw8200... installed windows home server x86 on it... and it only saw 2x 3.2ghz cpus.... I rebooted and google got me to
http://www.cpu-world.com/CPUs/Xeon/Intel-Mid voltage Xeon 3.2 GHz - NE80546QG0882MM.html
which says hyperthreading..
so I rebooted, went into the bios and viola.... HT was disabled..
what benefit is there to disable a feature that Intel incorportated??????????/
just curious... I have it enabled and will leave it that way unless it is dragging the system down... but I always thought ht was better than no ht...
Thanks!
Thanks!
