That about sums it up, though I was responsible for one setup where the plastic-style clamps, even though they were tight, somehow left a gap under the seam where the water developed a very slow leak. Replacement clamp didn't fix it, second clamp didn't fix it, and zip ties didn't fix it. Ended up having to replace the length of tubing (after draining the whole loop!), and used "proper" worm-drive clamps afterwards. Since then, I don't trust the plastic squeeze clamps, and don't like using worm-drives since it's easy to accidentally slice the tubing by overtightening. Compression fittings eliminate all of this hassle, provided you match the tubing to the fitting.compression fitting
advantage: easy to install, looks good, safest fitting ever
disadvantage, tube ID and OD need to be exact in order to fit in. realatively more expensive
barb fitting
advantage: as long as the tube ID fits the barb, you can use any wall thickness of tube
disadvantage: looks ugly to me, clamps doesn't feel as safe as using compression fitting, although i have never had any problem with using barb before.
compression fitting
barb fitting
Alternatively, you don't have to use clamps on barbs if you use a slightly smaller diameter tubing pushed onto the barb. Example: 7/16" tubing on a 1/2" barb. I use this method regularly if I'm not using compression fittings. Here's an example...
Very secure and looks a lot better than using a clamp.
hope you don't get a leak it is very unpleasant.
After probably 40+ systems built, odds are it won't happen.But you're right; I've seen leaks happen to folks and it does suck, but mostly that happens from negligence and lack of preparation. Sometimes, luck is just bad.
I've read information that said that compression fittings hinder waterflow...so if you're super worried about that then I'd go without compression. Otherwise, it's completely up to you. I currently use 7/16" on 1/2" with zip ties and it works great.
i also think they're a major ripoff. 5x the price of a herbie.I
the koolance clamps loose their strength over time if reused.
