gwarren007
- Apr 15, 2006
I seriously doubt that it isn't possible to dynamically allocate a specific amount of resources to a CUDA app. It wouldn't make any sense to impose such a limitation. Plus, ATI cards also don't have the ability to control GPU usage %. I suspect that the only reason the feature doesn't exist is simply because it hasn't been implemented.your better off just pausing the program then letting it run in the background as you game.. its not even F@H's fault that you cant limit the gpu usage.. its cuda.. the cards just arent designed to run at a specific limit.. they either run full out or nothing.. so your only choice is to down clock it..
