[U]ber|Noob
- Apr 4, 2013
I have two IR remote controls and receivers but the receiver for the most important pc has broken (it's generating gibberish) so I tried to connect the other receiver instead but it will only work with the remote it came with.
The other remote control was specifically set up for that pc, is there an easy way to get a new receiver or use the one I have with the existing remote.
They are both non branded remotes.
