Why aren't all SSDs SLC (optionally)?
Luke M
Most SSDs are internally SLC/TLC or SLC/QLC (the SLC being used for a write cache). So why not allow the SSD to be formatted as 100% SLC? Should be a simple matter of firmware, yes?
That would drastically reduce the capacity, and MOST SSDs will operate as SLC until the current workload exceeds the SLC cache, which would be the capacity of the "SLC formatted drive" anyway. I think you could format the SSD to be 1/4th the maximum size and get nearly identical results as a special SLC mode.
The benefit would be consistent performance and endurance.
As far as capacity, at worst it would be 1/3 (TLC) or 1/4 (QLC). Maybe a little more. Consumer SSDs have reached a comfortable size so that's not an insane trade.
Some archival, ultra-durable, and "industrial" SSDs are pure SLC. But beyond just the capacity decrease, there is a large cost increase in using SLC compared to even MLC let alone TLC or a variant of QLC.
It's expensive because it's a special SKU, not because it's complex. Straight SLC is simpler than SLC cache.
