ChronoDetector
- Apr 1, 2008
As some or most of you are aware, 4K TV's are currently limited to 30Hz thanks to HDMI 1.4 and even if the TV does support HDMI 2.0, you still will be limited to 30Hz at 4K because currently there are no GPU's that has HDMI 2.0 support.
Why aren't TV manufacturers adding DP on their sets, well apart from Panasonic who currently has a 65" that has DP on it allowing 60Hz for PC use, why do they insist on using that inferior HDMI 1.4 while DP provides more bandwidth? I don't understand, if they cared about catering 4K users especially PC users who want 4K at 60Hz, shouldn't they add a DP port?
