Why are these SATA connectors different?
Priddle
I am debating on getting this 3-HDD cage but the connectors don't look standard.
http://www.istarusa.com/rackmount_chassis/product/BPN-230SAS/2x5.25_inch_to_3x3.5_inch_SATA_and_SAS_Trayless_Hot-Swap_Backplane_RAID_Cage.aspx
There's a notch on both top corners of the black SATA ports. My SATA cables won't fit in those from what I can see.
Am I missing something here? Thanks!
Maybe SAS cables can be used in either SAS and SATA ports and SATA cables only work on SATA ports
Nevermind....I see how it fits now. The top of a sata cable connector is thin and not thick like the SAS cable I assume. Thanks anyway.
Correct SAS can talk to SATA drives
But not vice versa
ie SAS is a different language / protocol to SATA. it can wrap the SATA language inside the SAS language so it can communicate.
But SATA can't magically expand it's language to have the SAS language on top of it.;)
It's possible that the SAS ports are for the secondary ports on a SAS drive (since most have dual ports).
