Why are there so many Bluetooth devices in Device Manager and why can't I remove them??
Discussion in 'General Hardware' started by DaRuSsIaMaN, May 1, 2019.
  1. DaRuSsIaMaN
    DaRuSsIaMaN [H]ard|Gawd
    1,196
    Apr 22, 2007
    I'm having incredibly annoying Bluetooth problems with my Yoga Book--which by the way, is a piece of trash of a computer: highly not recommended, mostly because of (as far as I can tell) Lenovo's utter lack of providing driver and other support for this model.
    Anyway, I tried updating the driver, and it's telling me the best driver is already installed. I thought maybe I could just uninstall all the Bluetooth-related things and reinstall it using the driver I downloaded from Lenovo. (It's a driver from early 2017. Like I said, their support for this PC is next to nonexistent.) But I'm not able to uninstall anything! The first time I tried, it got to a point where it said I had to reboot to finish uninstalling. After reboot, every single one of the things I had uninstalled was back in the list! Wtf? The second time I tried to uninstall it simply got stuck on an uninstallation and I just rebooted because I wasn't about to wait for some unknown amount of time. Again, same result.
    When I go into View, and check "Show hidden devices", I get this giant list:
    So,
    1.) why is it that everything comes back after reboot?
    2.) how can I accomplish what I want, which is to remove everything related to Bluetooth and do a fresh install of that driver from Lenovo?
  2. DrLobotomy
    DrLobotomy [H]ardness Supreme
    6,229
    May 19, 2016
    Did you turn off BT in the BIOS? It will always 'come back' in Device Manager if you didn't.
  3. DaRuSsIaMaN
    1,196
    Apr 22, 2007
    Oh. No I did not, I didn't know about this. Thanks for that info.
    What about peripheral BT devices? Like, for example, my old phone is on the list but I don't use it anymore. That also reappears in the list after I uninstalled it.... Why?
  4. DaRuSsIaMaN
    1,196
    Apr 22, 2007
    Follow up question. If uninstall all the items and then turn it off in the BIOS, at which point should I turn it back on again? My objective is to do a "fresh" install of everything related to Bluetooth.
  5. DrLobotomy
    6,229
    May 19, 2016
    I would suggest turning BT off in BIOS and booting into OS. Uninstall the BT software now that the hardware is really OFF.
    Boot back into BIOS and re-enable BT and boot OS and see what happens. Windows SHOULD install the proper software.
