Why are PCs so slooow to POST?
I have a not so old Asus P5B-V motherboard.
As usual, with all PCs I've ever had or seen it takes a huge amount of time to POST and get started on loading the OS. Why is this? I could be wrong but powering up Macs, Playstations, Wiis, etc all take much shorter time.
I don't want to do rigourous tests on my system everytime I boot - how about only do this when there is a change of hardware?
My BIOS actually pauses to tell me it has detected a Sony drive - press any key (but continues after about 5 seconds)
...and what's with the tacky black and white ASCII graphics - surely we have evolved into pleasant GUI at this stage like all other non PC systems?
What thinks you?
:confused:
Playstations, Wiis, etc have the exact same hardware on every single one so they don't have to do a POST. The BIOS loads and hands off to the OS immediately. I'm not sure about Macs though but I would assume the same because Apple controls the hardware. It could also be related to EFI vs BIOS.
The biggest thing it depends on is your motherboard, try adjusting some settings, may make it POST faster. Also, I'm not familiar with that model, by any chance is it sold as a workstation board? Because if so, that's the main reason, I know my old P5WD2-Premium always took really long to post.
BIOS in itself is a relic. It is tiny in space, but the requirements of it keep increasing every generation. It is also programmed in a language that not many programmers are even familiar with now, so coding efficiency MAY play a role. BIOS will be gone in a few years, anyway.
