M76
- Jun 12, 2012
I have a CM Nepton 140XL AIO cooler. In a very well ventilated case. basically the Radiator has it's own compartment with 4 fans providing air flow.
With a 6800K running at 4.3Ghz 1.35V
The ambient temp is 24C Temp inside the case is 26C
But my CPU idle temp is 49C.
That seems extremely high to me. The pump is running at maximum speed, the fans are running @1100Rpm, which is slightly slower than the 7V test used in this test for example.
According to this the idle temp shouldn't be more than 10C over ambient. Still I'm getting 25C over that.
I've taken off the water block 3 times already to make the mounting better. I've even bent the retainers backwards to give more pressure (that actually helped about 2-3C it used to be over 50) I've spread the thermal paste in a thin perfectly even layer on both the water block and the cpu with an old credit card.
So WTF is going on?
Under load individual cores spike to 80-82C almost immediately.
These temperatures are worse than I should get with an air cooler.
So WTF is going on?
