Why are my temps so damn high?
Aardvarck
Hi all. I have a Winchester 3000. i've got it overclocked to 2.4 ghz (300x8) with the memory at 200.
my idle temp is around 43-45 degrees celcius and load is around 54-55 degrees celcius. now, i understand that the cpu running higher than it should will raise my temps, but should this be happening with an xp-90 and a 92mm Panaflo 57cfm fan blowing on it?
at stock my cpu idles at 40 degrees and load is around 49.
i'm using the correct amount of AS5 on the core, and the heatsink is secured in place.
my cpu temp program is Everest. i've also used MBM5 and got the same results.
any idea what the deal is?
40dgC is about average for the XP-90, and 55C is about right for a 300HTT Winchester... no worries here :)
