Sep 11, 2010 #1 hedron Limp Gawd Joined Apr 24, 2008 Messages 495 http://i.imgur.com/B7wmh.jpg How do I make them normal size?
Sep 11, 2010 #2 C Chuklr Gawd Joined Nov 1, 2009 Messages 787 hedron said: http://i.imgur.com/B7wmh.jpg How do I make them normal size? Click to expand... Hi, hedron, In the "Task Bar and Start Menu Properties" menu try unticking "Use small Icons" and see if that helps. Control Panel -> Appearance and Personalization -> Task Bar and Start Menu. Hope this helps. Chuklr
Sep 12, 2010 #3 hedron Limp Gawd Joined Apr 24, 2008 Messages 495 That makes them too big and the icons in the system tray are still small. Thanks though.
