Why Are Asus P45's Having Shut Down/Sleep Problems?
abcdelight
I have a problem that I have seen is not unique. I have an Asus PQ5-E that often will not shut down properly. Using Windows "Off" the computer sometimes won't shut off and I have to use the power button on the case.
Other times I try to use sleep mode and the OS and LCD go out but the computer stays on. I have to restart and then shut off with the button. Other times everything on computer goes off except the cpu fan. One day I turned computer off and came back home to find video card was lit up and on but without fan. The clock had stopped keepng time 5 hrs earlier when I first turned off computer.
When I turn on computer I often get "Windows did not shut down properly" warning etc etc". Doing searches I found a lot of people have had same problems but I didn't see any conclusive reason given. Is this problem a reason to send mobo back?
http://www.tomshardware.com/forum/250966-30-asus-computer-shutdown
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2226826
PS: I have latest 1406 bios, Vista Ultimate 32, 4850 with latest drivers, E6600 @default
After living with this awhile and tinkering with Bios etc it seems my problem was the EPU-6 engine (power saving application). When it was installed I had all the problems (fans/vid card stayed on in sleep mode, computer would awake by itself) - when I uninstalled it the problems went away. Prior to that - Bios updates, Cmos resets, power settings in Bios did nothing. My mobo was a Rev 3 as well.
Never had a problem with Sleep with my P5Q-D....
I use sleep function all the time.
One thing comes to mind... the software that comes with the Mobo for power saving features.
AI Nap or something like that... It basically does what you describe.
Have you tried removing all of the Asuses crapware?
The EPU-6 Engine is the power saving application. I installed all Asus software from their site (didnt use disk) and the power saving appilcation is only non essential I installed (no booster, probe, smart drive etc). When I had the EPU-6 installed I had it set to "performance" the whole time.
I didn't install the EPU-6 software as I was planning on overclocking and the software causes conflicts with it.
My P5Q-Pro has no issues going into sleep mode or shutting down.
My computer does still suffer from a drivers issue with Vista + ATI in that if I let my computer go into sleep mode then wake it up and log into UT2k4, UT3, or Vanguard I get a texture flicker that does not go away until I reboot the computer.
Yes I had a slight OC for a week or so and EPU-6 engine gave me alert that it was disabled by any OC (but I had same issues with an OC or not). My last issues are hang-ups and audio garbling while surfing web. Sometimes I run fix for winsock corruption and that fixes the problem but it just comes back. Maybe issues trace to my Vista and ATI cards as well. I'll check to see if waking from sleep states vs re-boot makes any difference.
I should add Asus does have a fix for instability issues with EPU-6 and I think I had used it since I downloaded in from Asus site same time I downloaded EPU-6 app but its possible I forgot to apply it. In any case I dont need EPU-6 anyway
The EPU-6 engine seems to be the problem, I uninstalled it because it does not
allow for overclocking, which is the reason most buy the board.
I don't think it's unique to the Asus boards, rather it's something unique with the P45 chipset. Why? Because my Gigabyte EP45-UD3P does the same thing... the shutdown thing really annoys me because the machine will just sit there and 'play dead' without shutting down completely. Sometimes after about 30 - 60 seconds it will finally power off, sometimes it won't power off at all.
My guess is a BIOS fix will eventually filter down from Intel themselves and all of the P45 based boards will eventually see a fix.
The EP45-UD3P has a power saving feature as well (DES). I did see a lot of people with some Gig P45 boards having sleep/hibernate issues as well once I began to look into the power saving features of these boards. Lots of people have fans that keep running etc. My board never performed poorly and its a peach now, but the one time I came home and video card was lit up but the card fan was off I didnt feel good using sleep mode. No probs now. When I saw "Climate Savers" sticker on box I was expecting a kick in nads somewhere along the line.
