Why am I so unstable?
BombThreat
So I just upgraded after a few years and now my computer will lockup randomly with a messed up screen... Like the video card is messed up... here are my spec, any help would be great.
AMD 4000+ 64
Biostar Geforce6100-M9
2 sticks of DDR 433 (512mb total)
1 stick of DDR400 (512mb)
Creative labs X Fi audio
80gb WD 7200rpm sata
420watt thermaltake PSU
Windows Vista Home basic 64bit
ill put money on RAM. run memtest a few times. and mis match sticks are never a good idea :p
But i had those stock in my other computer for years.... were can i find this progrm to test them?
- Run Memtest on each stick of RAM SEPARATELY for at least 3 hours, max 24 hours.
- Google, download, burn, and run Drive Fitness test to make sure that the hard drive is okay.
- Run Anti-Virus, Anti-adware, and anti-spyware programs
Even though your sticks of ram might have been fine in your other motherboard that doesn't mean your new board supports the entirely.
If memtest says each individual stick is ok, I would check for a BIOS update from your motherboard manufacturer. That may fix any problems a board may ahve with a specific type of ram.
Also, are you running the DDR433 sticks in Dual Channel? I cannot honestly say if it would matter BUT if you want to run all 3 sticks I would keep the DDR433 sticks in the Dual Channel slots and the DDR400 in the next set of slots, if that makes sense.
I just did a memtest for "all unused memory" for 30minutes. nothing came up. It was at like 250% complettion
As for what exactly I changed this is the following:
-Win XP Pro to Win Vista Home
-Abit AN7 to Biostar Geforce6100M9
-AMD XP2500+ to AMD 4000+ 64
-WD 80gb IDE Hdd to WD 80gb SATA Hdd
-I also removed my Radeon 9500 Pro because its AGP (no support)
Im wondering the following; could it be one of the following. The PSU not having enough wattage? (only have 2 cd drives, floppy and 1 hdd, no chassis fans. Or could it be the onboard graphics doesnt work well with Vista? Or maybe a defective motherboard?
lmao... that makes me feel soo good. i would pop xp back on but its not legit and i cant find my code...
New problem!
The last few times when the computer is shutdown for any amount of time (more then 20 minutes) It wont turn one via the front button. You gotta shut off the PSU then turn back on and then use the front button... Bad PSU or mobo?
Since that is a thermaltake powersupply, which are kinda bad, I'm leaning toward the power supply. But
New problem!
Know anyone with a PSU tester? ;) I know they are like $15 @ The'Egg.
"Why am I so unstable"
Too much Coffee?
Sorry, couldn't resist :)
That tells me there is an issue with the 5v section. It's not keeping it hot on the MB, which is required these days (and why you can't remove cards with the machine plugged in and turned off any more).
I'm still suspect of the RAM, but the PS is closing in fast. You didn't mention it's wattage so...
New problem!
Well the thing finally just wont show the display anymore... I had to retract all upgrades to the old computer so I have something to use. Tried to use the thermaltake and wouldnt work so I think thats dead.... It was a 420watt 20 pin ATX BTW. So I got my Antec 430watt 20pin and its workin just fine (in my old computer setup). Later today im going to put the new stuff back in with this PSU and see if that helps.
OH would it matter if ive got a 20pin ATX in a 24pin mobo?
I think they make 20/24 pin adapters, yeah...
Just wanted to say though, a thread titled "Why am I so unstable?" posted by "BombThreat". It made me chuckle.
