daphatgrant
Fi-yah!
- Jun 15, 2003
Extremely brief back story: I built a file/media server about a year ago and have been having recurring problems for about the last 8 months
. Long story short I've now replaced everything in the computer with the exception of the HDD's and SATA card and am still getting the occasional "A disk read error has occurred" "Press Alt-Ctrl-Del to restart" during boot. I've run S.M.A.R.T. tests on all of the drives and all came back error free, I've also done extensive tests on the OS drive and have had no errors. My next step is to replace the OS HDD and see if that resolves the issue.
Question #1: What HDD clone software do you recommend? My main OS drive is a 1TB WD black drive, I plan on buying another so I have an exact duplicate to clone to.
Questions #2: In WHS if the main OS drive fails are you fubar? Or is the info on the other drives salvageable? I can't just throw another drive in, install the OS, and have it pick up the files can I? I'm assuming this is a no as my system was about full (24GB free). All the files that I care about have file duplication turned on.
System:
Norco 4020 case
PCP&C 750watt PSU
Abit IP35 Pro
C2D E6500
4GB PC2 6400
(1) 1TB WD Black drive (OS) (attached to board)
(8) 1TB WD Black drives (Storage) (attached to card)
SATA contoller (here)
System:
Norco 4020 case
PCP&C 750watt PSU
Abit IP35 Pro
C2D E6500
4GB PC2 6400
