PoorBehavior
- Oct 23, 2004
I was considering a Synology NAS for $199 or so and my research kept pointing to WHS.
The easiest solution technically and the smallest as well would be to take my mostly unused backup system, a Shuttle SN25P and throw in one or two 1TB drives.
My intent is to backup specific items off of my main rig and my MacbookPro, be able to access the data remotely and as standard network storage. I don't plan on using it to stream media. WHS fits the bill and I don't think I will need a system that can handle ten drives. Will the Shuttle cause me any problems?
Am I being short sighted? If I decide I want to expand the array (not sure if that is the correct terminology here), can't I just pull the drives and put it all in a larger system or is it more complicated than that?
Thanks
Thanks
