Ok, so im pulling my hair out right about now...
For the past 3 days I've been trying to install WHS w/ the following hardwrae;
Gigabyte GA-MA69GM-S2H
Corsair XMS2 2x2GB 1.8V DDR2 800
(2) Supermicro AOC-SASLP-MV8's
Teac DV-W28S- R Slimline DVD-R
OS Drive - 640GB Western Digital Blue - WD6400AAKS
Storage Drives: (2) WD20EADS + (1) WD10EADS
Ok so here's the issue... I've tried installing fully load w/ all hardware connected to completely stripped w/ only OS drive + DVD-RW and still nothing... Here's whats happening. Using numerous methods (slow burns, max burns, downloaded ISOs, USB installs, etc), I'll get the disc to load screen where it says "Loading Windows System files" the progress bar continues to load as normal and does not stall.
Once it completes, I get the "Vista-like" green scrolling progress bar and it stays there in an endless loop. The progress bar never stops, it continues to scroll. I've changed SATA cables, tried installing via USB drive, and each method produces same results. Each method I use, and using the same discs, works on a different machine with different specs.
I'm gonna replace the memory here shortly, but anyone have any idea as to why it is doing this?
Needed to take a moment away from it to clear my mind so I thought I'd post here before heading back to it.
UPDATE: So all my hardware is good... I installed Windows 7 on the existing hardware and it installed fine - Have no freaking clue what the heck could be the issue.
