WHS for long term storage. How does it handle bit rot?
dydx
WHS works awesome as storage, but Im wondering in the long term if there would be issues with bit rot. I made a thread a while back suspecting bit rot to be affecting my music files (some of the titles and ID3 tags were messed up), but it turns out to be a false alarm and more so of an asian language + windows encoding issue. But still, Id like to consider bit rot as a whole and maybe how it affects us (if at all noticeable) in the long term, and not just on my music files.
I know WHS runs a CheckDisk every night at 12am, but is that sufficient to keep all my data safe in the long term? Hardware failure is easy to detect and fix, but the problem with bit rot is that it could be persistently damaging your files and you may never even know it. I'd rather my hard drive have a severe head crash on me so that I know about it, rather than having files to start going bad in the background without me knowing.
Here's an interesting article that I came across, which outlines the issue of using consumer grade high density SATA drives in storage. Basically what most of us use in our WHS.
http://blog.econtech.selfip.org/200...s-not-fully-readable-a-lawsuit-in-the-making/
Thoughts? How does NTFS based systems like WHS compare to other NAS units like Drobo, FreeNAS, whatever? Or am I just worrying too much?
Flexraid is working on self-healing, but at this time this function is only found on ZFS ( that I 'm aware of ) I am not sure that the BSD or Linux variants include this function, but I am sure the osol does, and perhaps eon.
Doesn't NTFS's spec have checksums and self-healing algorithms (chkdsk on a constant basis)?
