WHS, did i cover everything?
ganesh21
Just finish setting up WHS last night.:D
A8N-E Mobo
Athlongx2 3600+ (will down clock)
8800gtx(Temporary for video, will remove once everthing is done.)
750 watts (Temporary until purchase a 400 watts psu)
I use (2) 120mm fan @ 700 rpm for cooling.
Hard Drives:
WD 1 Terabyte
WD 1 Terabyte
WD 500 GB
WD 500 GB
Things I did so far:
Enable File Duplicator
Enable remote for one User only
Setup Window Home Server Connector on each PC
Setup backup for other pc in the house
Add folders, etc for all user w\ permission
Do i need to add a security suite or just add zonealarm?
Any add-in that is use full?
Did i miss anything important?
This system will be use to share software, movie, pic, music, etc to other computer and ps3.
Also, i would like to install Virtual PC, would it be any problem?
I will post picture tomorrow.
Go get Avast Anti-Virus for WHS. It seems to be the best out for WHS and is what I'm using now. Its also nice because all of my other computers use Avast so the console shows the status of every computers anti-virus.
My favorite add-ins are WHS Disk Management, Tab Creator, Whiist, and Duplication Info.
go check out http://forum.wegotserved.co.uk/. They have a lot of great information and add-ins on the site.
thanks for the info
Im using VMware Server to run Untangle and have no issues. Virtual PC shouldn't be a problem.
On another note, I once wasn't thinking when I was having problems with my WHS's network settings, and I disabled the network adapter. Needless to say, that cut off my RDP connection and there was no way to turn it back on without a monitor. I was VERY luck I still had a crappy video card installed so I could turn it back on manually. Think about that before you pull out that video card. :eek:
I don't have any low profile video card. I can always re-install it if need. I am just trying to keep it running with least amount of heat and noise. But i understand what i mean.
Today i add the 3rd HD and 4th HD. The computer would not accept all four hard drive. I will have to pick up a 4xsata Card. I look at newegg and they have a long list of cards. Some price from $25 to $400+.
Since WHS is handle the HD, can i just pick up a $25 card? If you have any recommendation/experience with a card please let me know.
I plan on adding 2-3 hard drives with the next 6 months.
Doesn't that board have 4 sata connections to support your 4 hard drives now? As for adding more SATA connections a cheaper card will work because you only need the ports and not RAID. The more expensive cards are hardware based for RAID. Just make sure it has un-RAID mode. These two cards will work....
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124020
http://www.newegg.com/Product/Product.aspx?Item=N82E16816132013
The board have 4sata connector. It just doesn't like it when i use all four port.
Thanks you for the link.
I just order the Syba SD-SATA-4P and another 1TB harddrive.
Make sure to get one of the disk management add-ins so you can keep track of which drive is which in case you need to pull one ever.
agreed i love the disk management, it took me a little while to set up the wire diagram, it wasnt the most intuitive design, but after i completed it i kind of felt stupid it took me soo long to make :)
I love advanced admin console, i am using it right now as a proxy server, since my work blocks all forums.... :)
I just got my WHS built this
I already install WHS using the onboard sata. 3 HD are connected to the onboard SATA.
I receive the pci sata card. The card install fine without a problem.
onboard sata: 2x 1TB and 1x500GB
Add pci sata card: 1x1TB and 1x500GB
I install the sata card and restart the computer w/ 1TB and 500GB connected. It will not load. I select to booth from onboard sata port 1. If i disconnect the two hard drive on the sata card, it load into the WHS.
This is what i was hoping to do. I wanted to add a stand alone sata card to add more hd to the pool.
If i am not clear on something please let me know.
Need to make a plug for Avast...right now they have a version which couples WHS + 10 users into a single VERY low cost package. I think three years is $150. That is like $4.5/year per machine for anti-virus coverage. Cheap as hell.
Enjoy
Side of Case
Front of case
HD: 2x1 TB and 1x 500GB
CPU- x2 3600+, 8800gtx, raid card 4port
Everything Install.
Back of Motherboard
Front of Case w/ Cover and two HD enclosure- 1x1TB and 1x500GB
All cover up and ready
Total Space:
4 TB
I will replace 500GB w/ 1.5 TB within the next 6 Months and also pick up 2 more HD.
I use this computer for storage, backup and sharing.
  • Movies
  • Music
  • Photo
  • Application
  • Games
  • Work
Back up
  • 2x laptop
  • 2x desktop
Thanks everyone for there input and help.
