I have been reading through threads for a while now and just wanted to pass equipment by all of you before I ordered final parts. I am wanting to do a WHS build that is fairly energy efficient with decent throughput. It will mainly be used to get the giant RAID array out of my workstation, but I will also probably start using it as a media server.
Parts I am thinking of are as follows:
Things I have:
Intel E4500
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115031
5x 1TB WD 10EADS
(got a great deal on them)
Things I am looking to purchase:
Motherboard: Gigabye G31 MicroATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357
Case: CoolerMaster Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Power Supply: PC Power and Cooling 610W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
SUPERMICRO AOC-SAT2-MV8
http://www.newegg.com/Product/Product.aspx?Item=N82E16815121009
Intel NIC
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106006
2GB RAM Stick
(whatever is rated decent and is cheap)
I would love to go with the Norco case, but it will have to be something I transition into. I will eventually transfer this system into a Norco and build the listed case out as an on location offline backup. I also already have a system in place for critical offsite backup.
The one other thing I was looking at is going with an energy efficient AMD processor like the 5050, but I thought it would be even more efficient to go with what I already had if there is no real performance advantage to the other.
Any feedback would be much appreciated.
Joshua
Things I have:
Intel E4500
5x 1TB WD 10EADS
Intel NIC
2GB RAM Stick
Joshua
