WHS box hardware change question
steven1110
I have a WHS box who’s cpu/mobo/ram is nearing 4 years old and I’m getting ready to update my workstation/htpc. Is it be possible for me to swap out the WHS components with the htpc components without WHS needing to be reinstalled or losing any data?
Thanks
Unless the HTPC and the WHS have very similar components you will have to reinstall windows. You shouldn't lose data assuming you don't format the wrong drive.
