theDreamer
- Oct 11, 2006
I recently added three WD15EADS to my WHS and have a few movies on the drives (other 4 drives are 1TB WD Green drives all at 98%). I went to stream the blu-ray .ISO files to my HTPC and it loaded fine and the movie started playing just as normal, but about 45 minutes into the movie it started to stutter as if it were buffering or something. I paused the movie and about 30 seconds later played it and it worked fine for the rest.
Since that one incident it has happened on most of the movies that are on the WD15EADS drives, nothing else has changed in the network. HTPC is the same, WHS is the same, I have tested some of the older movies on the 1TB drives and no stuttering issues from those.
My thoughts so far are:
~The WD15EADS are slowing the transfer rate or actually turning off completely
~My files are all corrupted or having issues
