I have an extra 1TB drive sitting inside my WHS server that is not yet "added".
It says I can add it as a backup drive or add it to the storage pool.
Does it make any sense to use an internal drive as a backup drive if I already have file/folder duplication turned on?
Does this copy NTFS readable files to the backup drive as a 3x "duplication" or are files copied to the backup drive in some sort of propriety "backup" format?
Would it be smarter to just drop the drive in an external enclosure and use it as an "offline" backup?
