WHS 03 shared dir's and HDD moving
SuperChicken
I've just finished setting up my WHS 2003 pc and I must say I'm loving it.
I used to just run in my desktop a 320, 500 and 750gb hdd's. I pulled the 500gb drive and
used it as the main drive in the WHS and I plan on picking up 2 1.5tb drives on Tuesday.
My questions are once I get the 2x 1.5 tb drives should I reformat WHS using the 1.5tb drive as the boot drive so that in the future if I decide to sell the 500 and 750 (possible for another 1.5tb or larger) I can do so? Or is it possible after putting the 3 drives (500 and 1.5 1.5) into the WHS I can change which drive it boots from?
Also is it possible to tell it that I want to remove a drive and it will shuffle files around so I can swap it out? Once I get the 1.5 1.5 and 500 drives working fine I'm going to dump everything over from the 750 and 320 and then move the 750 into it as well, filling my 4th and final SATA port. This is why in the future rather than get a sata controller I'd prefer to just op for a larger drive.
And lastly I noticed it starts off sharing the folders "music, photos, public, software, videos and printers". I'd like to remove and/or rename this if possible. Can I?
Thanks guys this is my first server build and I'm liking it already.
edit: The questions keep coming, is WHS with backup a good enough redundacy or is RAID 5 a better option? I initially had the mindset of building a server with RAID 5 no matter what, but when fooling around today installing WHS I think it's good enough to do the trick. I'm mostly going to have multimedia on it backing up just my photos, music and taxes.
No you cannot switch out boot drives by just making some clicks..you have to do a reinstall and it will save all your data but since you are starting anew I would use the 1.5tb as the boot drive if you think you may pull the 500gb in the near future.
You can pull out data drives and install larger ones.
Excellent I'll scan through this for some answers
Does it have it's own algorithm for storing the data on the drives? If I reformat WHS on my new 1.5 TB how do I go about loading the older HDD's back in. Do I just reinstall them physically and it repools and reassociates their data? Or would it reformat each drive when I added them?
OK, So I've got 2 1.5tb seagate, a 750 seagate and a 500gb seagate. For some reason I've tried installing WHS on the first 1.5 leaving it as the only drive connected. Works fine. Added the 2nd drive loaded fine, and pooled the data. However on reboot without attaching any other drives I get "BOOT DISK ERROR" and it won't recognize a disk some of the times. If I unhook the 2nd 1.5tb it works, and if I install the 500 in, it works as well. I format the non working 1.5tb on a different computer and hooked it back up and then the other (1st) 1.5tb was giving me the boot disk error?
You should pick the largest drive as a system drive from the start, upgrading system drives later on can be a PITA. And no you can't change boot drives.
Yep
Nope, this is hard coded, just disable them and delete their descriptions.
Create a folder with duplication enabled, thats going to be better than any sort of raid because you have data duplicated on two disks independent from any hardware or controller.
You can change boot drives but its a PITA its really easier to just reintsall and start over and restore your data...but it can be done if it has to be for instance if your boot drive takes a dump.
