whoops, window probs
renswic
ok while i was cutting my window desine(sp) i kinda fucked it up so i ened up going with a normal square cut
and it jsut dawned on me taht i wont be able to hide any cold cathode s on the bottem of my case i see one of 2 ways to fix it, doing my colored ones in a 4" kit in my drive bays(IF i can find white or purple ones) and one 14-15" UV one in the top of my case, would that work? most my new mobo(MB DFI LANPARTY UT nF4 Ultr NF4 939) is UV reactvie as is my PSUs cables, or should i jsut get a 12in UV kit and the 4 in colored ones?
if you need to hide a cathode, you can try putting in a small flap of metal to conceal it, from the window, but still add a lot of light to the case. depending on the case size a 12 inch really ought to do the job just fine
