Whoa... that was wierd.
pbXassassinX1524
okay, I have no idea what just happened. I was playing my brand new copy of UT2k4 then I exited and rebooted my machine (just to get a nice new start for... I don't know, I just felt like rebooting.
Anyway, I just hit restart and walked away, in the time it took me to make a hot pocket (apporx 2 minutes) something happened and I have no idea what. I came back and my machine was on, the monitor was in standby mode, and nothing would respond to anything. (the UT2k4 DVD was in at this time [the game play disk]) Then I took out the disk (everything had power) and hit the restart button on my case, nothing was wrong, no error report from windows, no log of anything happening... nothing.
I don't think that it was the UT2k4 disk that made it do that (though it may have) because when you install it, it makes you leave the disk in the drive.
Anyone know what happened?
Computer tried to boot from UT2K4 disc. You weren't there to see the non-system disc error where it tells you to remove disc and try again so it shutdown. No windows error because it never loaded or even tried to. Change the boot order in the bios so it tries to boot from the hard disc before the cd drive. That way you can leave your disc in.
mine just ignores any cd that isnt an installation cd, no modern drive will try to boot from a cd that wasnt burned to be a bootable cd.
Yes, same with my CD drive, unless it's bootable, nothing will happen. Floppies will still cause the system disk error though.
However, machine's fine right, pbx?
i have the CD drive in the boot order before HDD i think... like someone else said, it ignores CDs that arent bootable
as for floppies (i built my comp without a floppy drive and later added one), i dont have the drive in the boot order, i figure if i have a problem i can go into the bios and change it.
