Who makes axio power supplys
Crazy tech
I found an 600 watt axio power supply. I was woundering who makes this power supply because It's amps look good +3.3=32amp +5=50amp +12=24amp -12=1.0amp -5=0.5amp +5sb=2.0amp.
Remember that posted specs really don't mean alot when dealingwith no name manufacturers. I don;t know who makes it but I am always hesitant to a psu powering my components without a reputable manufacturer behind it.
Is the OCZ ModStream 520 Watt Modular Power Supply as good as the one in your sig but with lower wattage I'm on a somewhat tight budget. :rolleyes:
Its a much better PSU... remember, watts mean nothing nowadays. That 600W unit has a lot less amperage on the +12V rail than the Modstream. Oh, and do run the numbers.
I came up with 348.5 but I think the 6800 draws more then the 5800 maybe I need and minimum 400 to be safe. But until I can afford to buy a new power supply,which of these two is better achieve at 500 watts or the sparkle at 400 watts which I have sitting around?
