who makes a USB repeater/access point?
u2slow
I work in a place with no cell reception or wifi. Yah. Weird eh?
There's *one* networked PC. I don't have the freedom to change any of the existing setup as far as a wifi router etc. The only thing I could away with - maybe - is something I could shove in the USB port to act as an access point. It would have to be autoconfiguring, or pre-configurable (woah. tall order?)
Since my Blackberry Curve has UMA and Wifi, it would in effect give me full cell phone reception at work.
Who makes a USB gadget like this? Everything I can find seems like a basic USB wifi adapter and its unclear if it can work the 'opposite' way at all.
Its usually a PITA, but you could do a Adhoc network (peer to peer) with just a normal wifi adapter.
