Who has reached 1200FSB on their Intel Processor?
USMC2Hard4U
Tell me if you have reached 1200Mhz FSB on your Intel Processor. What cooling you had to use, what chip you had, what speed its at, and what your memory ratio/speed/timings are.
I am curious to see because I want to know if I am too far fetched in thinking I can Vapo Chill a Dual Core EE to 4200Mhz/1200MhzFSB.
Thanks
my spec below..
RAM was Apacer PC3200 with timings 2.5-6-6-3, CPU DRAM ratio 3:2
CPU was P4 2.4Ghz D1 stepping
was using stock heatsink with ys-tech 7000rpm 60mm fan and AS5
both cpu and heatsink flat lapped. cpu lapped until copper core
you really should ask for a photo to prove it. Like this.
Then ask them to post up some bench proof you see sometimes people get there machine to post long enough to take a cpu-z shot but that is all. Then pretty soon the bull shit starts to kickin and the next thing you know hell they benched there at those heights daily. So ask them to prove it or don't post!!
You saee there in the little window that I was 3659 which is about 305.5 fsb at about 1222 bus speed. Now Aquamark I benched at 3689 or 307 fsb which is about a bus speed of 1228
http://arc.aquamark3.com/arc/arc_view.php?run=953933834
Well getting over 1200 is getting easier now that you can lower the multipliers on newer processors. With the Northwoods you had to make it with what you had, there was no changing.
WZ
