WhiteFox Custom Mechanical Keyboard - $105.87
Or just get a cherry equipped ducky for the same price
The board you linked is not comparable to the OP. Fullsize vs WhiteFox custom layout is the most obvious but there are many differences between them.
You can get a TKL from Ducky for a similar price, that uses cherry switches also. It's not like this whitefox keyboard has an advantage other than being an inch and a half shorter than a normal TKL. To say it's got a feature over a 60% would make sense because it still has direction keys but even that still exists on mechanicalkeyboards.com with cherry switches in a couple varieties.
Other than the layout, which isn't unique to the WhiteFox, what are some of the many differences?
I can think of a couple, neither of which is an advantage.
1. No name mechanical "knock off" switches.
2. Ridiculously high retail price.
Aluminum body, USB-C, arguably better keycaps, fully programmable keys, different layout vs TKL (not better or worse, just different)
Sucks it doesn't come with the Hako switches in the ebay ad, but Kaihua kailh are hardly a no name "knockoff".
The only argument I see for the Ducky is that it is cheaper/similar price and uses Cherry switches. If that's the only argument then you can say the same against the Ducky, plenty of options cheaper that use Cherry.
I own a Ducky (One TKL RGB) and a NightFox, along with a few other boards.
Reactions: File
