VMWare ESXi host. I may even duplicate this to do testing and learn about multiple hosts (vMotion, etc.). I'll be installing on a 4GB USB drive.
Under $1,000
US - VA
Motherboard, CPU, RAM, Case, Power Supply, Hard Drive or SSD
Nothing
6) Will you be overclocking?
No
I have a 1600x1200 Dell that I'll use for set-up.
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Optional, but would be nice: Onboard video, multiple Gb NIC, IPMI, mATX
I have a Technet standard subscription that I'll be using for my Windows guest licenses. Other guests will be Linux variants.
Below is what I have my eye on at this moment. I'd appreciate if anyone can point-out any obvious problems. I was planning on getting an SSD to hold some local datastores, and for the rest I'll be playing around with iSCSI using other parts I already have and FreeNAS, etc.
Motherboard: Supermicro X9SCM-IIF-O
CPU: Xeon E3-1230 V2
RAM: 2 x Samsung DDR3-1600 8GB (found using this compatibility list)
Case: Fractal Design Mini Silent (I could go cheaper here, but I just like this case. Aesthetics are important to me...can't help it.)
Power Supply: Rosewill Capstone-450-M OR, since it's on sale: Corsair H650
SSD: Crucial M4 256GB
I appreciate your thoughts. Thank you.
Under $1,000
US - VA
Nothing
No
This week
