white water waterblock dimensions?
tastyratz
anyone have the dimensions of the white water waterblock or would be able to measure it real quick? I wanna get one for my pentium D socket 775 but ive been told by some people it wont fit alot of 775 mobos.... and I wanna take the dimensions to see for myself
Minus the part which straps to your board:
Block:
Length: 75mm
Width: 50 mm
Height: 18 mm
Retention plate:
End - end: 75mm
middle - middle (It's wider in the middle than the ends): 98 mm
Width: 80 mm
Barbs:
center to center: 240mm each
Left to right barb: 480mm
height: 33 mm
Screw mountings for retention plate:
Lenfth: 68 mm
width: 38 mm
Block:
Length: 75mm
Width: 50 mm
Height: 18 mm
Retention plate:
End - end: 75mm
Width: 80 mm
Barbs:
height: 33 mm
Lenfth: 68 mm
width: 38 mm
The barbs are nearly 1/2 meter from left to right? OMG that's a huge spread!
