White Water w/ A64?
orkan
wondering if anyone is using this block with an A64, and wether or not it works well.
I know the WW was originally designed with exposed cores in mind. Not sure how it will work with an IHS.:rolleyes:
It will work well with any setup. The IHS doesn't limit the effectiveness of the waterblock at all.
and even if your worried...get the mobile A64...it dont use a spreader
White water blocks don't work with A64 mobos because of the mounting hole pattern.
edit: You could get the WW to fit an a64 with a little work..
mine came with an aluminum bracket...
is that not for use with the A64?
