White Midi Towers?
Darth Bobo
Hey All,
I'm pondering a new system come spring if I'm lucky and have started looking for white midi towers to checl´k my options seeing that I'd like to do a white box.
So far I have found these options:
Corsair Graphite SE (White)
Fractal Design (White)
Coolermaster CM 690 II Advanced (White)
My question is twofold:
1: Have any of you had experience with any of these cases, how are they? (I have a friend who recently did a build in a black R3, sadly I didn't get to screw around with it)
2: Are there any other white midi tower options out there worth considering?
TIA :)
I know i am extremely happy with my Corsair Graphite 600t.
my only complaint is the stock fans don't seem to push much air. They seem to be doing the job but it might just be because my house is cold as heck.
It also has plenty of room to work with. I have my eye on the Fractal design case too, but I am so happy with my 600t I don't plan on buying a new case for a long time.
I helped a friend build a system in an R3 and I thought it was a really well-designed and well-built case. For the price it's pretty hard to beat.
I can recommend the Antec designer 500. It is the successor to the P150 which was also white. It is the Antec SOLO case, except in white with a 5oow psu.
It is one of my favorite cases, I have built 4 systems, using the same design. The white case color is stunning. This design has insulated sides, and other quiet features. It can handle a graphics card up to 10". More if you will mod the drive cage a bit.
You may have to shop around for it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129036
I have the black 600t and I LOVE IT. I do agree with the other guy tho fans dont move much. Amazing cable mangement and its extremly roome. I plan to get two evga gtx 570s along with liquid cooling i love the case.
Fans dont move much and the fan controller doesnt do much.
just looking @ pics from google.. the fractal & cm are '100%' white.. the corsair isnt.. if it were me, i'd go the fractal :)
I'm torn between that and the Corsair case, the Fractal Design R3 has the advantage that it is readily available and cheaper than the Corsair case, the Corsair case is just [H]ot. Luckily I will not have to choose right now. :)
Btw: thanks for your comments everybody :)
