white horizontal lines as gpu artifacts?
Discussion in 'AMD Flavor' started by leadays, Jan 8, 2017.
  1. leadays
    leadays [H]Lite
    78
    May 31, 2016
    When i play games in fullscreen i get white horizontal lines flashing on the screen about every 30 seconds, i also get them in the game menu, tested on two monitors over VGA and HDMI. It happens at different resolution and different refresh rates.
    It doesn't happen when i play games in fullscreen-borderless and in windowed mode, only happens in fullscreen.
    I removed the drivers and installed a different version but it doesn't solve the problem.
    It happens more often when i have unlocked fps, the gpu is always under 50C.
    I think it's the gpu, what do you think? If that's the case i will upgrade in a few months.
    I have an i7 4770k overclocked at 4.4Ghz, r9 380 non OC, 8gb 1600mhz ram.
  2. noko
    noko 2[H]4U
    3,659
    Apr 14, 2010
    Underclock your GPU - Test
    Underclock your memory - Test
    Underclock both - Test
    Play around with Wattman, raise voltage etc. also to see if you can isolate cause.
    Change frequency of your cpu/memory as well just in case it is a RF issue.
    It could still be issue with drivers and Windows install as well. So see if anything affects this behavior.
    leadays likes this.
  3. leadays
    leadays [H]Lite
    78
    May 31, 2016
    I tried it but without positive results. I've booted from a backup disk with windows 8 and i didn't see any line for a few minutes of csgo, tomorrow i'll install the exact driver version on window 10 and play for a bit.
    All those driver releases and the only changes I've noticed are these white lines, less options for monitor calibration, more frequent driver crashes.
    thanks for the help I hope installing an old driver is enough.
  4. noko
    noko 2[H]4U
    3,659
    Apr 14, 2010
    Wow, what a headach! - Now I did forget one very important one - cable - switch out the monitor cable, switch ports on the card as well.
  5. aznever
    aznever Gawd
    552
    Sep 7, 2010
    looks like your video memory might be going bad. I would suggest RMA it before warranty runs out.
  6. leadays
    leadays [H]Lite
    78
    May 31, 2016
    I've installed a very old driver and i don't see any unwanted white line. If the problem started with the latest driver why wouldn't previous versions work? I had to go back to a months older driver, but everything works for now.
    I don't think i can rma the card. I had ordered a 390 from amazon marketplace but they sent me the 380 and didn't allow me to send it back for reimbursement. I contacted amazon that refunded me and let me keep it, so i don't think i'm entitled to any assistance. I'm planning to upgrade in the next months anyway.
  7. TheLAWNoob
    TheLAWNoob Limp Gawd
    346
    Jan 10, 2016
    They didn't let you send it back, but gave you a full refund and let you keep it? Am I reading this right?
    Also, that doesn't mean you can't do RMA with manufacture.
