oOo sam lee oOo
- Aug 29, 2004
if i wanted a black case, but i couldn't get a black case, would a super cheap solution be spray paint? would it look ok?
i think you meant powDercoat... not powercoatdarktiger said:If it is a metal or alumium case, then yes spray paint or powercoat it(there are a lot of good guides, just do a search). If the case is plastic then use vinyl paint.
trust_no1 said:
