White Cable Sleeving
yowen
I will probably be needing around 20 - 30 ft. of 1/2 inch white cable sleeving to organize cable going along my white baseboards. I am thinking that'll make them look a lot better.
It will be one DVI, one Power, one usb and probably an audio cable. I figure 1/2 inch should fit the bill?
I was looking at 1/2 inch split nylon mesh sleeving from cableorganizer.com
http://cableorganizer.com/woven-wrap/
Just wondering what you guys might be using or if you have some input on this. Thank you!
