Which X800 XL Model should I get?
Ghostface Killah
Well I was looking into the 6800 non ultra but I learned that the X800 XL is a better replacement for it. In price and performence.
So now the question is; which model should I get?
Ati X800XL.
ATI 100-435500 Radeon X800XL 256MB 256-bit
MSI RX800XL-VT2D256E Radeon X800XL 256MB 256-bit
They're both identical except for the two dvi slots, and the other being an OEM (Even though if it was an retail it would not matter.)
I am leaning towards the ATI version, since it is the true brand name.
check monarch for a connect 3d X800XL card going for 250$ shipped. Its up to you, but for a 30$ diffrence id go Connect 3d
http://www.monarchcomputer.com/Merc...M&Product_Code=190527&Category_Code=ATI-PCI-E
He is referring to the above card. It is indeed cheaper, but it is lacking 4 things compared to the Asus one.
1. A decent heatsink
2. VIVO- it only has tv out unlike the asus
3. Dual DVI
4. Retail Package
Now you just have to decide for yourself if you need any of the above and if it warrants an extra $32. Hope this helps!
PC-HAngover said:
http://www.monarchcomputer.com/Merc..._Code=ATI-PCI-E
3. Dual DVI
4. Retail Package
Dont forget the DDR as opposed to GDDR3.
Asus sucks.
wait wahh? I didn't even catch that. Can someone verify that the Asus X800 XL doesn't actually use GDDR3 even though it should?
I will be rather upset if that is true, and yes I see that newegg lists it with "DDR" memory, but hopefully someone can say something different because I really wanted dual DVI and VIVO.
check it out on the Asus site if you like.
They pissed alot of people off when they released the Asus Ultra "Extreme" too.
450 Core Clock and 900mhz DDR
All the retail stores had to stop carrying them cause customers were complaining they just paid 650 dollars for something that performance worse then a stock 6800 Ultra. I think Asus discontinued that in a month but they stick DDR on quite a few models including GTs.
Theres the fact sheet for ya.
http://usa.asus.com/prog/spec.asp?m=Extreme AX800XL/2DTV&langs=09
I know that GDDR3 has more bandwidth (or is allowed more?), but how big of a performance hit does the Asus X800XL take compared to the ATi version that has GDDR3? I was really looking forward to getting that Asus X800XL after trying to decide on a BFG 6800GT OC or the Asus o.o might go with the 6800GT now I guess, even though it costs more... /shrug
the x800xl is supposed to preform on par with a 6800gt...and usually does..but it's cheaper
it doesn't have SM3.0 which is becoming a issue now though
Product Details
* Bulk (OEM)
* Manufacturer Product Specifications
Provider: PowerColor Corp
