wingedleopard
- May 15, 2008
If I wish to be certain that I have devices running on different rails, how do I know which wires or connectors to use?
For example, I have an Antec Earthwatts EA380. I run a 65 watt CPU and six HDDs--that's all. The specifications from Antec say that it has two +12v rails--one for the processor, and one for the motherboard and peripherals.
All six disks were connected to the same wires (three molex connectors in parallel with splitters to dual SATA power connectors). Two hard drives were not being detected by the BIOS or the OS. These two disks happened to be connected at the very end of the chain. I moved them to the other wires (the other chain of molex connectors), and now they are detected just fine.
Based on the specifications from Antec, both of these two chains of molex connectors should be on the same +12v rail, so it shouldn't make any difference. I can offer two alternative hypotheses:
(a) They are actually on separate rails, so those two disks are now supplied with sufficient amperage.
(b) They are on the same rail, as Antec claims. Because they were at the end of the chain, with all of the disks spinning up at once, sufficient amps were not available at the end of the parallel chain when needed for detection. Moving the connection to the other chain allowed the amperage to balance more evenly between the disks during spin-up.
If (a) is true, I just need to put three disks on each chain, and I should be fine.
If (b) is true, I think I need a PSU that can handle more wattage.
Would you agree?
Responses are appreciated!
Would you agree?
