which way should i go
Status
Not open for further replies.
exdeath85
im going to buy a new pc im not sure if i should buy parts from newegg and go with a system builder
iv read some disturbing topic about avadirect. Is there truth to these topics about fraud and bad customer service.
Is vigor gaming anygood and should i go the high road and buy a pc from puget system
im into high-end gaming like mass effect 2, crysis, gta4, supreme commander like games,dragon age orgins, bioshock1and2, halo2, command and conquer 3and4,red alert 3
i want a pc that get 50fps in all theses game but under $2100
im typing this topic for feedback from the community any suggetions are welcome
o and is resellerrating website reliable
first and easiest: reseller ratings is generally reliable, yes
second and fairly easy: you can easily achieve your desired performance (depending on resolution and IQ settings) for easily under $2100 in all of those games except GTA 4 and Crysis (because they just run like crap regardless of hardware) and Bioshock 2/C&C4 (because they're unreleased and performance data is unavailable, so its anyone's guess what it'll run like, suffice to say, decent modern hardware will run them though)
now on to more serious matters:
I would avoid "system builder" types like ibuypower or whatever the latest nonsense is, they use substandard parts, slap the boxes together, and will leave you high and dry to make a buck
if you want to buy a pre-built machine, I highly, highly suggest Dell, Hewlett-Packard, Alienware, or Falcon Northwest, just to save myself some time retyping, read through this thread:
http://www.hardforum.com/showthread.php?t=1492005
I would suggest the same machine to you that I did to him, except perhaps in your case grab the 5870 instead of the 5770 and you should be happily good to go (if you'd like to shop around at HP, Dell, etc and find a better price, be my guest, I'd love to see what you can come up with :))
Personally,I never had much luck with the big name companies like Dell,always found their support sub-standard. There are decent "boutique" builders out there,you just have to do some research. I got the system in my sig for $2000,including overclocking,from Max Force PC,and it's performed flawlessly with every game I've thrown at it. Maingear PC and Puget Computers are also highly recommended.
Build your own PC, you'll get a much better machine for less.
Status
