Which Video Card I need ?
WhDemon
I just bought a new Computer
Basic Mobo with GeForce 7060PV/nForce 630a onBoard /w Pci-e
Amd x2 5600+
2Gig DDR2 Ram
160gig Sata-2 Hdd
520 Watt PSU /w 2x PCI-E Power
I need a card that can Play games like Bioshock Crysis Oblivion @ 1024x768 Mid-High
I use Vista
I dont have 300$ To spend on a Vid Card.
then look at the ati hd3850 (256mb/512mb) or ati hd3870 (512mb). seeing how u play at that low of resolution also look at the 8800gt 256mb which is better performing than the others.
*nvm the 3870. no need for 512mb. just look at the ati 3850 256mb and 8800gt 256mb
Well, what do you have to spend on a graphicscard? Finding one at $299.99 problably won't help you even if it's technically less than $300.
$200? In that case you are probably looking at the Ati HD3850 based cards or pehaps better the nVidia 8800GT@256MB cards (http://www.newegg.com/Product/Product.aspx?Item=N82E16814125085)
$100? Probably end up with a 8600GT card or 7600GS, not sure they would cut it though...
dont spend on a video card less than the 3850 unless its like $50 or something. its worthless if u do IMO
If you have less than $100, go for an overclocked 8600GT 256MB (don't get the 512mb)
If you have more ,go with the 3850 or 3870.
HD3850 or 8800gt, depends wether you like ati/nvidia :rolleyes:
Yeah go for it, they cost more then that in the bloody uk anyway.
How about that Thing
8XXX Support Direct x 10
HD 38xx Support Direct x 10.1
uh 256 u mean ?
Yeah sorry, I just looked at the desciption text underneath all the pictures...
Tigerdirect.ca said:
XFX GeForce 8800 GT Video Card PCIe 2.0
Redefine your gaming reality with the NVIDIA GeForce® 8800 GT 512MB PCI Express 2.0 graphics card featuring the world's first DirectX® 10 GPU and a powerful unified architecture that delivers an incredibly true-to-life gaming experience. Power through games at record speeds and charge through game maps with vividly realistic, sun-up to sun-down HDR lighting effects while steering clear of mind-blowing physics effects such as explosions, fire, and smoke. And when you're not destroying the enemy, relax watching your favorite movies with NVIDIA PureVideo™ HD technology.
10.1 is a bag of shit and it makes no diffrence to anything IMO. Get the 8800gt and dont worry about dx.
Works fine apart from it constantly running at 29%.
Can't hear the diffrence if you crank it up to 40% and the increase in cooling is huge.
Budget might not stretch enough.
I'd say see how the card pans out and if needed buy the S1 later for $25
wow that card looks Awsome lol.
Im using 667 pc 5200. Its cost 21$ for 1Gig.
