Which upgrade would be best for me
Boardin087
My system specs are in my signature. At the moment i mainly play WoW and other games and work in photoshop a bit with a dual monitor setup. As the next school year starts ill be doing more programming and 3d graphics. I was wondering what upgrade would be best for me. I was thinking of swapping for a new Mobo/processor however might just get another gig of ram for the time being. A problem is that i cant find ram with the same timing i had been using with my mushkin (2-2-2). how big of a deal is this? Thanks for any help you can give me.
The thing about this upgrade is that if you change your mobo and proc. then you will most likely be changing other parts as well. If you stick with AMD, the newer mobos are either s939 or AM2 which means that the graphics port will be PCi Express so your old AGP graphics card will not work.
If you go with a new AM2 mobo, your old ram will not work. You would need DDR2 + a PCi Express card.
Yes it would be more of rebuild at this point. Another thing is your PSU. Depending on the hardware you upgrade to, you may need to replace that as well.
If you don't want to upgrade everything, do some research and find out what the fastest socket A processor is. That way you can just plop that in your old mobo and use all your existing hardware. It wont be a major jump in performance though.
bare minimum with a video card using pci-express thats is better then the one i have how much would it cost me. I do not want to be cheap on the mobo/processor/ram but i know vid cards have a large price range.
IMO, I'd wait till either conroe comes out or there is more variety to the AM2 board line. And you are definetly going to be looking at a rebuild over an upgrade, with a new board chip you are going to also have to look for a new V-Card and and possibly a new PSU I'd shoot for at least a 480watt unit, Antec & OCZ are good choices. You might also need to look into DDR2.
to answer the initial question, the best upgrade would probably be your ram. It doesn't sound like you're a big gamer and WoW isn't heavy on requirements either. A gig of ram would be your best bet, and it doesn't need to be an exact duplicate, the faster ram will just clock down to the speed of the slower ram. As has been said though, you're really not gonna be able to salvage anything from that set up as far as a new rig goes, so maybe just save some money (i have almost the exact same setup). Maybe check out the FS/FT forum?
