D
Deleted member 1778
Guest
Okay, I currently have the following.
DFI LAN Party UT NF SLI-DR motherboard.
Athlon 64 3200+ that will do around 2.3GHz stable and 2.5GHz stable for about 6-7 hrs.
1GB (2x512MB) OCZ EL Platinum Rev 2 PC3200.
GeForce 7800GTX
Ive decided its time for an upgrade, and Im not gonna jump ship on AMD just yet.
Choice #1 (~$330.00):
EVGA 122-M2-NF59-TR Socket AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard - http://www.newegg.com/product/product.asp?item=N82E16813188016
AMD Athlon 64 X2 3600+ Brisbane 1.9GHz 2 x 512KB L2 Cache Socket AM2 Processor - http://www.newegg.com/product/product.asp?item=N82E16819103046
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - http://www.newegg.com/product/product.asp?item=N82E16820231087
Choice #2 (~$240.00):
Keep my existing Socket 939 motherboard
AMD Opteron 165 Denmark 1.8GHz 2 x 1MB L2 Cache Socket 939 Dual Core Processor - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103588
OCZ Enhanced Latency 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit System Memory - http://www.newegg.com/Product/Product.aspx?Item=N82E16820146883
If I take the first choice, my old stuff would go in a spare case with extra hardware Ive go laying around to put on my network as a fileserver and print server. Currently, my main box is spending most of its time being a file/printer server anyway. If I do this, I can get the extra hard drives out of my gaming rig and actually turn the damned thing off at night. Plus I have further upgradeability. At least until next week when AMD discontinues AM2 and goes on to something else for a couple weeks.... </sarcasm>
Choice #2, is simply cheaper and I could do the whole server thing with an old P3-600E I have laying around.
Naturally, the video card would stay and I'd see how far I can overclock whichever processor I end up with.
GeForce 7800GTX
