- Feb 13, 2006
I have been out of the computer upgrade loop for some time now. I'm currently on a 9700k, 32gb G Skill DDR4 4000, Asus PrimeZ390-A motherboard, Nvidia 3070ti, and my monitor is a Dell S2721DGF (165hz 1440p gaming). Not sure if I'm missing anything else. Before this I had a 3770k for about 3-4 years. I don't game like I used to, but I want something better for PUBG. I know anything I get will be leap years better, but I'm not sure which path to take. Miami finally has a Microcenter, but it's a good 4 hour drive, lol. I just want a good deal on a new setup and want to go to one of their stores. Fuel isn't an issue since it'll cost me maybe $25 or so.
So 9800X3D's finally came out, and I know supply is scarce. I'm not sure if I should spend the $679.99 on the mobo, cpu, and ram combo, since it'll most likely be overkill, but at the same time should easily last me 5 years at my current pace. Do I save $80 and upgrade to the 7800X3D combo (mobo, cpu, ram) for $599.99, which still is overkill, but again should easily last me 5 years. This is also in stock and I won't have to wait on it. There was a new 7600X3D that was recently released and it's only $449.99 for the mobo, cpu, and ram combo. This is also in stock, but the downside is that it's only 6 cores/12 threads vs the 8 cores/16 threads of the 7800X3D/9800X3D. I know any route I take will be light years ahead of my 9700k. Going the 7600X3D would save me either $150 or $230. It runs much more effiecent also at 65watts vs 120watts for the other two.
Almost anytime I've upgraded in the past I always went with the best, but now I'm feeling like I don't need to go that route with how much of an upgrade even the 7600X3D would be. If I go this route am I going to miss the extra 2 cores/4 threads? I'm going to game on 1440p, typically run PUBG on medium settings, and after phase 2/3 I usually turn everything to very low. I most likely will upgrade my videocard in the future, but if I don't have to I won't. This is another area I'm so lost at. Would my 3070ti bottleneck the cpu's? If so, which gpu do I consider? If I went with the 7600X3D would I be able to upgrade to the 9800X3D later on if I needed an upgrade? I'm kind of lost on the zen4/zen5. Here is the 7600X3D combo and there is an upgraded mobo for $50 more here. If I go this route is the basic combo fine or the upgraded one worth $50 extra? I'm almost talking to myself like going the 7600X3D route would be the best, but let me know if I should spend the extra $120/$230 for one of the other two. Case! What's a good case for these?
Thanks in advance!
Thanks in advance!
