I need to cut a 12" x 14" rectangle window with 1" radius filleted corners out of an 1/16" aluminum side panel. Should I use my bosch mag router, bosch variable speed jigsaw, or should I jsut try to find long lost dremel?
I'm not used to cutting metal, as I generally make a jig or template for cutting wood.
or will my carbide tip bits just get f'd up by cutting metal?
