That is intense!! thank you for the info Topweasel. Sounds like way too much hassle and risk for ~5 degrees.
5-10 depending on setup. Thats the difference between HT on and HT off for some users.
Can't touch it without the gloves and you have to run your system really hot the first time you use it. Like 90 Celsius hot. At $20 a pop for about 5 degrees, not knowing what HSF configurations it will work with, keeping it imperfection free, and running your CPU without a fan to the point of throttling, doesn't seem like its worth the effort.
I mean read this.
http://indigo-xtreme.com/docs/indigoxtremeinstallation-1155-1156xtremeclean.pdf its a 20 step process.
none of those links have data on the IC diamond? from the looks of that huge chart though, AS5 still works fine if you still have some (which i do lol)
mostly within 1-2 degrees difference between eachother is nothing to stress about.
As for Great contact, I might have gone a little overboard; no block on the market has contact this great.
