Which temperature sensor to trust (Intel)
AproXi
Hello Guys and Gals,
When i'm stress testing my cpu (i7 930) @ 4.2GHz on my Asus Rampage III Extreme. I see a big difference between CPU Core(1,2,3,4) temperatures measured by DTS (Digital Themal Sensor) and CPU-temperature measured by Winbond/Nuvoton W83667HG sensor.
CPU Stress: ~90 C (DTS)
CPU Stress: ~65 C (Winbond)
The idle temperatures is almost the same with both sensors. ~45 C
Anyone who know a bit more about this and which sensor is to be trusted the most?
I trust the thermal diode that is on the CPU. On windows Realtemp or CoreTemp will read these or the coretemp driver on linux. I believe these will not be the Winbond sensor.
RealTemp or CoreTemp, the other temp is from a diode in the socket, most likely, and so won't show accurate CPU temps.
