devil_trigger
- Jan 24, 2007
Hey guys, I monitor the rig in my sig with speedfan and TAT, and I was wondering which temp sensor I shouldt rely on most. Speedfan has a cpu temp, then a core0 and core1 temp, and the cpu temp always seems about 5-6C higher than the core temps. Also, the core temps on speedfan and TAT usually match, maybe off from each other by 1C sometimes, and TAT doesnt have a CPU temp, just the cores. For example; running Orthos, speedfans "cpu" temp maxes at about 52C, while the core temps max at about 45C, and TAT reports about the same as speedfans "core" temps. So should I look at the "cpu" temp or the core temps?
