Which Stacker?
texuspete00
I'm mostly torn between the 810 and STC-T01. Is the biggest difference just the extra 120mm fan in the 810? I like how the T01 can take a second supply and I believe even the 4 in 3 kit in the back instead in case you had a big rad up front. Am I missing anything?
Heh, maybe I'll flip a coin. A second 120mm near the mobo could be nice, but I don't want to give up too much other possiblities. The 4 in 3 kit fit in the back of both choices?
What's a matter folks, stackers too pricey? Hell I'd consider the 830 but looked too ricy to me.
What I'm looking for "is the case to end all cases." Ok, so i know that might be impossible. But I spend a lot of money on comp parts and something that might last an upgrade or two, would be worth it. Hm... might take a look at the thermaltake. With Conroe coming, what's imperative is the case goes to BTX. Or else it has no chance of lasting a year.
Well, if you want BTX then the T01 or the new 820 will work. The 810 doesn't do BTX. But if you want a case that will do both ATX and BTX the T01 is your only choice.
Then go for the T01....
BTX isn't going to take over in a year :p AMD still has yet to adopt it.... same with all the other companies.
I don't see BTX becoming mainstream, the origional reason was the heat from intel procs, now that they have moved to a new design there isn't a need for BTX.
i think either will make you happy. I like the dual 120's on the 810 though.
