which ssf should i choose?
Malikman
hey i was wondering which ssf i should choose....
aspire q-pack OR silverstone sugo sg-1 evolution
I'm leaning to evolution but i heard q-pack's are flimsy (obvoiusly correct me if i'm wrong)
anyone here's my rig that will be going into either case
Proc: Athlon 64 x2 3800+
Case:Silverstone sugo-sg1
Motherboard: BioStar TForce6100-939 or Foxconn 6150K8MA-8EKRS (comments would be great)
Ram:Corsair (2 x 1 gig DDR 400)
Graphics Card:XFX Geforce 4 7800GT Pci-e
PSU: 400-450 watt from pc power and cooling
Watercooling: I don't know anything about watercooling and am trying to figure out how it'll fit into the csae i have chosen ideas would be great.
i'm probably actually not going to do watercooling but AIR for awhile then watercooling later.
If your water cooling, I;d say go with the X-Qpack because it has room on the back to mount a 120mm rad. Though you could mount the rad on top of the other one I suppose, with a lot of cutting.
Check out this thread for a good picture of the Shuttle G, Shuttle P, X-Qpack & Silverstone SG01 sitting side by side. It gives a good visual perspective on the size of these cases as they relate to each other.
http://www.hardforum.com/showthread.php?t=978420&highlight=x-qpack
The x-qpack is flimsy compared to a quarter inch bar of steel, but I think its plenty strong for its intended purpose once its assembled. I wouldn't use it to sit on and certainly wouldn't use it as a stool to stand on, but my x-qpack sits on the back seat of our 4WD when we go off-roading and hasn't been tweaked yet. The x-qpack is much more flimsy with the cover off (as it should be by design), but that doesnt matter to me because its the system as a whole (when assembled) that counts for me and so far its been just great. I do look forward to the day when somebody takes the best of the x-qpack, silverstone, shuttle, etc, and puts those features in a new line of cases.
